Any1 wants to buy a brand new A'PEXi AVCR???
we need at least 5 or more ppl to buy together...
i think the price in aus is around 900~1000, correct me if i'm wrong
I'm gonna to order them from HK
it will take about 2 weeks time b4 they arrive
The price will be around 500~600 depends how many ppl buying
i'm in Brisbane, so ppl from Brisbane/Gold Coast area only
now...only 2 ppl buying....so we need 3 more ppl
if interested...plz give me a call on 0433135474
PS ppl wants to buy other performance parts can also ordered together
cheers
Daniel
https://www.sau.com.au/forums/topic/28555-apexi-avcr/
  • Replies 41
NismoGirl:
Thanks for the correction....
i went to some shop they quote me for 900.... :D
i thought it's a bit too high, therefore, i decided to buy it from HK, which is still cheaper than australia
Slamm:
If you are interested, then plz give me a call...
we should arrange a time to meet up
i live in Sunnybank....
cheers
Daniel
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-590920
Im of the opinion that AVCR isnt that hard to fit yourself
its the SAFCII thats hard
ide just get both and get both installed at the same time
Why do you say the SAFCII is hard to install knore?
I've got one in the mail and I was intending on doing it myself (installing that is, I'll leave the tuning to the experts)
You've got me all worried now...
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593547
avcr is easy to install and tune your self - but its crap.. only single soleniod. Get a HKS or Greddy.
SAFC is easy enough to install, but not tune yourself.
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593563
Thanks dAVE.  As I thought...
Benefits of duel solenoid over single solenoid?
Not sure how it works but I know it makes boost come on better. There are many threads about this on the forums. Also price wise, you can get a greddy profec B for 450 new and it has duel solenoid... you just dont get the riced up screen, but the HKS EVC 4 has that :cheers:.. and alot more classy than apexi.
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593580
A searching we will go...
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593581
While we are 1/2 on the topic here, i've got a S-AFCII in the mail coming over and i've read the wiring diagram on the apexi website, it doesnt seem hard to install and i think i could do it myself.
What i wanna know is after i directly install it can i drive the car without it being tuned, like does it have a base map or still use the exisitng ecu's A/F ratio untill its tuned?
If i do this it will save me $$$ on the install and ill leave the tuning for the experts
Thanks
Matt
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593884
MJ,
So long as you can install the unit ok and set it up as per the instructions (ie cylinders, tps, afm settings) you will be fine.
The SAFC will be effectively zeroed out and wont make any changes to the air flow signal.
This is exactly what I intend on doing with mine until it goes on the dyno...
NismoGirl:
You wouldn't happen to know if Gavin tunes the SAFCII's would you? Approx price? He uses Dysons dyno doesn't he?
Your gunna have to start compiling a price list for him... j/k :cheers:
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593901
Thanks for that strutto, i shouldnt have any drama's setting it up, but if i do i guess thats what these forums are for hehe.
I'm thinking of getting Gavin to tune mine too....but i suspect he will be pricy as he will have to use someone else's dyno. Whats the name of the workshop that Gavin uses's for the dyno? could be easiest just to goto straight to that place?
Cheers,
Matt
P.S sorry for the hijack
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593966
I just asked the same question re the dyno... I believe he uses Dyson Rotarys dyno but I could be wrong...
I don't want to bag the workshop but I wouldn't let the guys at Dyson tune mine... Same way I wouldn't let Gavin tune my rotor if I had one... (Not that thats gunna happen)
I've seen some of his (dysons) tunes and haven't been overly impressed...
P.S This is like the biggest hijack I've been in ever... And it doesn't seem to be stopping either... :D
https://www.sau.com.au/forums/topic/28555-apexi-avcr/#findComment-593982
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
