Anybody else played this?
It's only new out, maybe a few weeks. There's a demo for single and multi player.
I've been playing it over the net for the last few hours and OMG it's addictive.
I might actually buy this one ;) ;) ;) ;)
Bad thing is it's a 132meg download for the demo :eek: :eek: But gezz the graphics are good.
Anyway - enough talk, I'm going back to playing :D
https://www.sau.com.au/forums/topic/2856-battlefield-1942/
Well I had a go and well it wasn't smooth running.
First I would load the game and it would crash back to the desktop with a beep.
Applied a patch, DX 8.1b etc etc. XP SP1..
Seems to load but now it says my cd key is in use..
I returned the game as I checked the Forums on the BF www site and apparently there is ppls going around using the cd keys some how..
I can send off to EA to try and get another cd key but as other members of the forum have stated a few days later it is in use again.
I really can't be bothered... Game returned money back..
https://www.sau.com.au/forums/topic/2856-battlefield-1942/#findComment-67780
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
