Just wondering if anyone can recommend a good car-nut-friendly drawer of domestic house extension plans that can knock up a set for me?
Looking to build a large brick double garage/workshop onto the side of the existing double garage, somewhere to put the overflow of toys from the current shed, and to be a peaceful haven for the boys who hath sinned and been banished from the household.
Someone with experience in designing workshops (who can suggest stuff like power/lighting layouts, hoist clearances/positioning, etc) would be perfect, but can probably work out most of that myself if necessary.
Cheers,
JD
https://www.sau.com.au/forums/topic/285699-anyone-know-a-good-draftsperson/
I don't have specific experience designing workshops, but i produce drawings all day long and have had a reasonable amount of experience. I would be happy to give you a hand with it as i too would like to have my own special place one day.
let me know if you want to meet up and discuss the project further.
Cheers Donnan, i'll be in touch.
Do the ACTLPA mob require that the plans be drawn up by a registered or certified person? I've never had to deal with them before as my builder always took care of that stuff, but unfortunately he's retired now.
I have another builder in mind that we have used before, but he just said to get some plans drawn up, then he'll give me a quote.
I have no idea about boundaries, easements, development vs building approvals, public notices etc, etc.....which all really sucks, because I just want a shed.
Im a draftsman, 8 years experience, most in Victoria
The rules and regs change from state to state, but also willing to help out if I can too! (I do 3d representations, detail plans, footings, drainiage and elec, timber frame stress analysis, shadow projections, submission to council plans, the works)
Drainiage and roofing is the biggest concern as the council all wonder about the extra water catchment area the roof provides, thus feeding it back into the stormwater system... they dont want to have to upgrade pipes in the area (can design that for ya to)
I specialised in WSUD (Water Sensitive Urban Design) in a major Land Development Consultancy in Melbourne
I also have a few contacts here in ACT with residential expertise so maybe I can get them in contact with you.
The initial plans can be done by anyone ,but usually require someone registered to sign off on them (approvals etc)
Theres a guy about 600m from my house here in Deakin, Rod Sheather Architects & Builders (he is a car luver too)
Will also come by one evening after work and have a geezer if you like?
Might chat about car electronics again!
Edited by MAG86
ACTPLA has no requirement that your plans are drawn by a 'suitably' qualified person only that their good and legable and include all the relevant info and are drawn to scale. Donnan can draw them and his experience eclipses my own. Have you looked into the Development Assessment Requirements? And whether your application even needs assessing at ACTPLA or possible be seen by a private certifier?
Can provide more info if you like?
Shit, I thought i'd be lucky to get one reply, and there's three of you?
Do you guys all know each other? Maybe you can just all come over one arvo, i'll supply the beer :laugh:
Good point on the Development Assessment stuff Adam - I tried to work out from the ACTLPA website what sort of approval it needed, if any, and just got more confused.
I guess knowing the floor area would be a good start, so i'll have to measure it up again. From memory it was going to be something like 8m x 7m, so around 50 - 60 sqm.
I'm off to NQ on Friday for a few days, but i'll give you all a shout early next week. Whoever's intererested and available can come check out the site (i'm in Calwell if that matters).
Thanks guys,
JD
I shouldn't draw for you, as i work in Development Assessment (DA) at ACTPLA (it would be a conflict), but I'll happily discuss with you the in and outs or the system to give you the best chance of a nice smooth process. Drop me a line at work on the customer service number 6207 9123 and ask to speak to Adam, I can email you a heap of info but that doesn't really help. Have you got a quick sketch of what you want and where on your block?
Actually, I was thinking of just going out to ACTLPA with the block plans in hand and having a chat about what I want to do. Is that the done thing, or is it a formal process with booking an appointment first? You guys are still out at Mitchell right?
We're at both Mitchell and Dickson, if you want DA advise come to Dickson (we're opposite the motor registry, in the south building). Mitchell might be able to help you out, they're at 8 Darling Street (close to the corner of flemington and sandford). No need for an appointment, unless there are some contentious issues.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
