hi guys
im looking to buy my first car.
my price range is around 8.5k $
looking for a sporty 2 door car (like a skyline r33 ,integra,prelude,celica)
good condition with rwc, preferably black but im open to anything.
my emails
[email protected]
so email me if you have something!
open to any suggestions!
cheers
https://www.sau.com.au/forums/topic/286234-looking-for-p-plate-car-vic/
i get more responses in this section
The Wanted to Buy section is there for a reason.
Perhaps if you were that genuine you would actually keep an eye out in the for sale section.
Don't crash and die in the new car, that would be a crying shame...
still looking guys! p plate car!
Hi, I have got a black 300ZX targa Non turbo.Call me on 0439818008 and come and have a look.I am in Mordialloc Melb.
cheers
Alex
hey champ i've got a 97 tf magna manual 3.0l no mods done perfect p-plate car, i bought it for while on my p's goes hard as, suprising for a magna i know but the 6 can realy boogie when you put your foot down. has smoked a stato 5l before. let me know. im in melb so pic up no probz.
