Built Rb25 W26 Crank/rods/headwork/cams, Inlet Maifold And Fuel System, Are Alloy Rad And Cooler, Rb25 Box And Kit To Convert 32, Blitz Spec R Boost
Stripping out my 32 as need to get some cash together as building a house. Chassis is also for sale if you wont a good drift/track project
In Adelaide but wil ship, some parts still in car but can remove when required.
Engine: R33 RB25,2630cc?, fully built engine by Nisspeed here in Adelaide. Engine was built, engine dyno tuned and fitted in car, we used it for 12 months at about 4 drag meets and very little street use. Engine was stipped down to check it out and have a look, sump baffels were istalled, new rings and since then it has only just been started. Engine includes
RB26 crank balanced, streightened and ground
RB26 rods preped with ARP bolts
ARP cradle studs
Wiesco forged 87mm pistons
sump mods for anti oil surge
Metal head gasket
N1 oil/water pump
New thermostat
RB25 head ported
HD valve springs
HKS? 272 and 264 cams ( one was new the other as good as cant remember the exact specs)
HKS adjustable exh cam gear
ARP head studs
RB26 clear cover - modified
R33 CAS
Rocker covers painted gloss balck with -10 fittings for the breather pipes
engine does not include inlet/exh manifold/PS pump/alternator/ but can include parts if needed
Price: $5k
Inlet:
Custom inlet manifold on std runners - old Subzero type one, with 70mm? 5ltr holden throttle body
Includes alloy fuel rail with 75lb ~800cc Holley injectors
Sard pressure reg
Injectors, reg and fuel rail were new, mainfold SH but polished up
$1200
Fuel System
SX fuel pump, good for 700 HP
SX fuel filter
Alloy surge tank with pump and filter mounted on plate
Fuel cell about 30 ltr and lift pump
all conected with stainless braided teflon lines, all parts purchased new
$700
ARE cooler, 600x300x100 Bar and plate, 2.5" inlet, 3" outler,
anyone that knows ARE stuff know it is top quality, with cast end tanks for optimum flow etc, barely a mark on the cooler
$800
ARE 40mm radiator, duel pass cross flow, fits my 32, not sure if 33 etc are the same, includes large themo fan (15" ?)
$600
R33 RB25 gearbox, good contition still shifts smooth as, includes slave cyl
$1000
Conversion kit to put R33 box in R32 includes modified 1 piece tail shaft, modified gearbox mount
$100
Also have cooler piping in 2.5" and 3'' stainless, painted silver with tial BOV, and inlet pipe, 4" with big K&N filter can can include some of this if you buy multiple parts.
Blitz Duel SBC spec R boost controller, as new, $500
Dyno sheet attached of what the car did on the roller at about 1.4 bar boost
Please contact me by email [email protected]
Radiator and fuel system sold
may swap engine and or inlet setup for standard items plus cash
Sorry Chassis sold
hey mate how much u selling chassis for? defected?
Engine/Radiator/Cooler/fuel setup sold
Still have Inlet manifold with injectors and fuel reg - sard and boost controller
Will post pics in the next coupld of days now that they are out of car
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
