Comes with Laptop Cable, Software. $600 ono
  • Injector types eg, Multi-Point 1, Multi-Point 2 & Throttle Body
  • Anti-Lag, Drag and Rally
  • Selectable sensor applications eg. Magnetic or Hall
  • Selectable triggers
  • Selectable No. Cylinders
  • Selectable Ignition types
  • Stage Injection
  • Boost Cut
  • Rev Limit (Rev Soft)
  • Rev Cut
  • On Board Map Sensor
  • 2 Auxiliary outputs
Each o/p has 12 options – eg, Boost control, thermo fans,
NOS, Tacho, Warning lights, A/conditioning control,
Water Methanol Inj., Shift light, Idle control, Cam control
(Vtec), Fuel pump control with automatic safety cut out if engine stalls, and many more.
Displays current status of engine. ie:
  • Water temperature in Deg C ( -20 to +235 )
    Air temperature in Deg C ( -20 to +235 )
    Manifold pressure in K.P.A ( -100 to + 155 )
    Engine RPM ( 0 to 12500 )
    Fuel pulse in milliseconds (mS) ( configurable )
    Battery voltage in Volts ( 6.5 to 23 )
    Throttle position in % opening ( 0 to 100 )
    Ignition in Deg. advanced (Static to 51° )
Inputs
Built in manifold pressure sensor to measure engine load.
Barometric pressure compensation. (Auto compensation for different weather conditions and changes in altitude).
Internal battery voltage sensing and compensation.
Air temperature sensing (compensation to Fuel or Ignition)
Water temperature sensing (compensation to Fuel or Ignition)
Programmable for different Air/Water Sensors.
Selectable - Hall, magnetic or optical on trigger circuit.
Selectable - Hall, magnetic or optical on sync circuit.
Throttle position sensing
Outputs
Adjustable ignition timing ( 0 - 51 Deg. Advance in 0.2 Deg. increments).
Adjustable dwell control ( 0 - 5 mS).
4 Ignition outputs for sequential ignition timing.
4 injector drivers incorporating 4 to 1 current ratio for injector response and lower power
https://www.sau.com.au/forums/topic/28718-ems-stinger-4424/
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
