Hi,
I'm looking at selling my car which was freshly imported from Japan.
This is a September 1994 GTR32 Silver in colour. It is in full original condition and has a few mild mods when it was imported into Australia in June 2009. The rest of the car is totally stock and untouched.
The car was imported into Australia with an N1 engine built in Japan. It has a RB26X engine serial number and 24U stamped on the block.
Compression test done and came out 160psi on all 6 cylinders. It also has a different oil sump but I have no idea what model it is. The engine also looks much much newer than the other parts in the engine bay. Engine head is also almost brand new. Suspect it was a crate engine installed in Japan since it also has an engine serial number. Odometer reads 105,000km.
It has cross drilled rotors, Trust Catback exhaust, stock airbox with HKS highflow panel, stock suspension, stock GTR32 rims.
Since it arrived in Australia, I have since changed the following items:
- Power FC Pro with handheld controller tuned by Chasers Motor
- Hawk performance brake pads for all 4 brakes
- Genuine Nissan O2 sensors X2
- Bosch 040 intank fuel pump
The car runs great except for slight whining noise from the aircon compressor (inspected and confirmed by the mechanic)
The rest of the car is in total original condition and it is a very very well maintained car. The car is always parked in a secure sheltered carpark and it is used only on weekends.
Selling the car for $23,000 with rego till July 2010. Car is located in Melbourne.
Reason for selling: I need to free up cash for other commitments.
Please sms/call 0402-120-107. No time wasters or test pilots please. Lowballers will also be ignored as the car is really in a very good condition.
Any pictures?
Was this a personal import?
Will post pics up tonight. This is not a personal import. The price of the car is neg. It is really in excellent condition and the engine is running as new.
  • 1 month later...
Engine in the car has the same engine as what is stated in the topic below:
http://www.skylinesaustralia.com/forums/Rb...Nu-t192670.html
It has an X at the end of the engine serial number with an R directly above it.
Of course the engine serial number is different from what is in the topic link.
The engine looks very new and is definitely a different shade compared to the rest of the components in the engine bay.
Compression tested to be 160psi in all 6 cylinders.
Car recently fitted with
1. 3" high flow metal cat from Dandy exhaust
2. 5 X Defi gauges (Boost, Tacho, Oil Pres, Oil Temp, Water Temp) --> (Last 3 gauges are Defi BF series with white light)
3. Blitz IColour boost controller tuned to 1bar
Defi gauges and boost controller will come with the car if the price is right.
Genuine reason for selling.
Edited by meowdog
Text message send to your mobile
cheers
Alex
  • 8 months later...
sounds ok, but need some good pics ? i would'nt be interested in offering you anymore than $15,000 ... last year i also bought a R32 GTR though mine has a REAL RB30 OS GIKEN block ,nismo head. engine is still worth over $20,000 plus mine has a full nismo body kit ... message me if u wont to sell at a 'realistic' price !!! ,,,
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
