hey guys,
i have a BLACK R34 GTT that i am considering selling for parts as its had a crash, the front left has damage from where it hit a tree.
The engine does still start. Never had any problems with the car
The car had about 120,000kms of genuine kms i have the papers from japan, also have a manual with it.
Car had its 100,000kms service done, and has been serviced every 5000km since. All interior is fine, i will post up some pics soon, its located in geelong, VIC. looking for some interest either in parts or the car as a whole...
Thanks
https://www.sau.com.au/forums/topic/288725-r34-gtt-wrecking-black-rb25det-neo/
hey mate,
is it a manual? cause im after a manual steering wheel. is the airbag deployed?
is the car a 4 door or 2 door? cause im also interested in the driver side A-pillar
  • Like 1
Hi mate sorry to hear,
Was the car a manual? I might be interested in the clutch and brake pedals, clutch master cylinder and slave cylinder, the tailshaft, the trim around the gear stick.
To do a auto/man conv on a 34.
thanks Gman n msports. it sucks but could b worse :)
i knew id forget things sorry guys, feel free to call or text msg me on 0408340465 (if i dont answer just leave a msg) pm on here or email me [email protected] and i will get back to u ASAP
i seem to be only able to send a couple pms a day though.. so email might be easeir for me to reply to questions than pms.
the car is a manual, and it is a 2 door.
R34wong: cant reply to ya pm sorry coz i have replied to too many but yer sure thing.
Battery: u mean engine and gearbox right? give me an email, call or text please
mainyard: u have dibs then mate
aznbongsta: yer the interior parts thats fine, spoiler i may be keeping sorry, pick up would b fine id have to pull stuff apart first but.
the airbags did not go off
John: its a manual 2 door, airbags didnt come out, and yer the a pillar would b fine too.
msports: thats all fine
Gman: radiator support bar is no good sorry gman
hi mate jsut woundering if ur selling the aircon controls also how much for the rb25det neo?
thanks!
ps: im from geelong too
Edited by Tuff_Skyline
hey tuff, good chance il b selln everything unless i can get the whole thing sold to a single person which i would prefer but may not happen. so yes aircon stuff is fine. battery may have gotten in b4 ya, give me a pm with ur number and il let ya no if things fall through k champ :)
PM's recienved although cant wb to all yet as limited amount of replies a day for some reason... yer bonnet is screwed mate lol, it had an intercooler which has become no good coz it got bent, a pod which is also no good, and a turbo back exhaust which should b fine... it was only lightly modified... and all that was done by my within the last year as i brought it stock as a rock. also had tineted windows, 18 inch speedy inferno wheels black wit silver lip, and aftermarket kenwood sound system... hope that helps, thanks :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
