1993 S1 R33 Gts-t.
129,xxx km’s
Timing belt changed at 100,000km
2 Pak respray was just done
2 way sunroof
Tinted windows
Viper remote start alarm
HKS Turbo Timer
Drift Boost Gauge
Kenwood MP3 head unit
6” Alpine front splits
6” Focal rear coaxials
4 gauge 2 amplifier wiring kit fitted, including 3 RCA cables (All ran to the boot)
Genuine Trust No-holes front mount intercooler with 3 inch piping (No holes cut in the chassis)
3” Turbo back mandrel bent exhaust with 3” high flow cat & stainless steel split dump pipe
Splitfire coilpacks
Turbotech boost controller (Running 9-10 psi)
Pedders heavy duty front & rear sway bars
Front & rear strut braces
Cusco adjustable pillow ball tension rods
Rear subframe uras pineapples
Hicas lock bar
11 months registration
$12,000
Either PM me or contact me on 0401 651 796.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
