For Sale
Nissan Skyline R33GTST Series 2 1997
Manual
102402kms
VIN 6u9000ecr3313037a
Engine No. RB25197227A
Has years rego
Just had RWC 2months ago without any problems
Time to sell my skyline..
has been a fantastic car to own and drive! will make someone very happy,
but it has to go due to wanting to buy other toys.
The car is locatated in sale Victoria and as it is a fair way out i am willing to drive to meet those who are interested.
just had a service including new spark plugs, oil, belts, filters etc changed
tune is currently a low boost due to beening daily driven and made 320hp atw (can supply dyno sheets)
has made over 400hp atw on current set up
if i have missed any details please let me know
here is the list of all the goodies it has
Haltech Platium Pro (pre release version)
REPLACED OIL PUMP (at approx 87,000kms)
REPLACED WATER PUMP (at approx 87,000kms)
REPLACED ALL BELTS (at last service)
Tyres are a few hundred kms old
Fuel filter just replaced approx 1000kms ago
BLITZ LM FRONT MOUNT INTERCOOLER
GReddy RADIATOR
ELECTRIC THERMO FANS
SARD COOLING THERMOSTAT
CUSTOM GARRETT TURBO (turbo spec will be supplyed to new owner)
NISMO FUEL PUMP
NISMO 555cc INJECTORS
NEW TOMEI z32 AFM (not hooked up due too haltech ECU)
SOLID INTAKE PIPE
TEIN SUSPENSION – Checked by Fulcrum in Cairns in 2008 – they said it was all good
BRAIDED LINES THROUGOUT ENGINE BAY
SPLITFIRE COILS
TOMEI PON CAMS
SARD FUEL PRESSURE REGULATOR
GREDDY OIL CATCH CAN
NEW RADIATOR HOSES AND SILICON LINES
HKS SSQV BLOW OFF VALVE WITH PLUMB BACK KIT TO MAKE LEGAL
NEW CLUTCH & LIGHT FLYWHEEL– NPC BRAND - Rated to 500rwkw from memory, super bitey with really nice pedal feel.
ALARM (M40mongoose alarm with extra feature add-ons from DEI) –complies with Aust insurance standards.
ALARM TURBO TIMER – BUILT IN
AUTO BOOT RELEASE FROM REMOTE
AUTO HEADLIGHTS
AUTO WINDOW ROLL UP KIT
FEDERAL 595RSR SEMI SLICKS ON REAR (255 wide 17")
FEDERAL SS595 FRONTS (235 wide 17")
CARBON PILLAR TRIMS
NISMO FLOOR MATS
P4004 ROCKFORD AMP
P6001BD ROCKFORD AMP
PIONEER SPLITS
SUPER WHITE HEADLIGHTS
post-46539-1253441124_thumb.jpgpost-46539-1253441356_thumb.jpg[attachmen
t=246965:20092009032.jpg]post-46539-1253441853_thumb.jpgpost-46539-1253442031_thumb.jpgpost-46539-1253442147_thumb.jpgpost-46539-1253442221_thumb.jpg
ASKING $23000 ONO
Cheers Michael 0448445300
https://www.sau.com.au/forums/topic/288791-skyline-r33gtst-series-2-for-sale/
Also open to any reasonable offers, pm or msg me anytime
Cheers Michael
Hey mate. Time to sell it on hey?
This is my old car, I can vouch for how much work was done on it - lots of money spent and very fast.
Good luck with the sale - if I wasn't selling off stuff to renovate my house I would be tempted to buy it back hey!.
  • 3 weeks later...
  • 1 month later...
can vouch for this car, replace the clutch in it a while back before it moved on to the thread starter, and it is a very very nice piece of machinery, will dust a 19g r33 gtr EASILY!
no offence but ppl are paying just over 19,000 for r33 gtrs
read what i've said above, i really can vouch for this car, if i didnt have 3 bloody nissans already i'd love to snap this up as a daily driver with alot of grunt!!!!
  • 4 weeks later...
is anyone out there interested? make me an offer? im starting to really need the money, its a great car as all have said, heaps more in it to!!
  • 1 month later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
