I have a Genuine NOS nitrous system that i have never needed or used. Its a full sport compact 50-150hp wet kit as displayed here...(item 7) ($990)
http://www.horsepowerinabox.com/HPIABV8/category7_1.htm
extra accessories are a brand new purge kit as displayed on the link above...(item 9) ($180)
NOS black powdercoated thicker aluminium bottle brackets ($300)
NOS nitrous purge led light as seen in the following link (item 6) ($49)
http://www.bottleorboost.com.au/NOSaccesories.htm
NOS bottle gauge ($55)
NOS nitrous filter (item 3 2nd link) ($89)
NOS bottle warmer (item 7 2nd link) ($235)
Autometer dash Nitrous gauge ($110)
Extra lines and fittings ($180)
over $2100 spent...save over 33%
$1350
https://www.sau.com.au/forums/topic/288927-genuine-nos-nitrous-system/
  • 4 months later...
  • 1 month later...
I'm keen but I need to find a place who will be able to do the install for me before I can think about buying....do you happen to know anyone/shops in melbourne?
fly me down and ill do it...easy
call Rajab Racing or JPC in Melbourne.
Edited by Swiper the Fox
