I think you'll find alot of shops will be reluctant to loan their booths .. in case of misuse or negligence (and insurance reasons) ... a well ventilated garage can do the trick if you get desperate.
there's a place on aldenhoven road at lonsdale next to blue monkey creations...i hired that booth to spray my skyline.....just cant remeber the business name at the moment....i'll get back to you on that one
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
