Hi all,
A mate has this damaged lance gsr sitting in his garage collectiong dust. He's willing to let it go for dirt cheap, like $1500 as is, no rego.
It has a Jap 1.8lt engine in it, still running the standard Aust delivered ECU but the Jap ECU will also come with the car. Missing front bumper but he believed its also somewhere in his garage.
If i wasn't already working on my own project, i'd have got it off him as the in-famous popullar DT PANEL quoted me around $3K to $4K to fix. This is the Aust version so it has that cool green boost thing that light up when comes on boost :D.
These still worth around 8K to 10K on the market, even just to use it for Track Days or DECA only is still consider a dirt cheap option.
Can i leave this in Vic section for at least a week before this get move to the forsale section? Reason is i'd rather see a vic member get a good deal than anyone else or the WRECKER!
Only serious buyer thanks, please pm for further details.
https://www.sau.com.au/forums/topic/289170-damaged-lancer-gsr-forsale/
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
