Hey guys, i've got a standard r32 GTR aluminium bonnet up for grabs. Its in very good condition in white, and is basically plug and play if your car is the factory white.
Use it as a replacement for your carbon bonnet, keep it as a spare, or even as an upgrade for your GTS-T :D
Im asking only $525 for it, preferably pick-up from a friend's workshop in Blackburn, VIC. I can even organise a respray to suit your car at a good rate if thats what you need. I will also be able to organise shipping for an interstate buyer at your expense, but I doubt it will be cheap considering the size of it.
Pics to come soon once I get a chance to drop by Blackburn. But before that, its just a standard white 32 GTR bonnet with no damage whatsoever.
Contact me by calling 0433 438 086, or drop me a text if I dont answer.
Cheers :huh:
Edited by Yawn
https://www.sau.com.au/forums/topic/289530-r32-gtr-factory-bonnet/
Back up for sale!
New price is $425, urgent sale. It is in very good condition, just plug and play :D
Contact me at 0433 438 086
Edited by Yawn
To all the people who have asked, yes the bonnet comes with the underside lining.
Oh and please direct all enquiries and questions about the bonnet to my PM or through this thread, as the number above is no longer in use and will not be able to be contacted.
On the other hand, if you would like to arrange pick-up, please contact my mate Alan @ 0433 260 991, the owner of the workshop in which the bonnet is stored. Just hand the cash to him and pick it up :D
Just to let all interested buyers know, I went to inspect this bonnet today, and let me say, its FAR FROM 'very good condition'!
Bonnet barely has any paint left around the edges, and as well as that, countless marks, scrapes and areas where the paint is damaged!!
hey matt
could you please pm me about the condition of the bonnet in some more detail.
Not really stressed about the paint side of things just what condition is the metal in ???
cheers Bud
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
