Ive got a black R34 GTT skyline coupe for sale.
Heres the details:
1998 R34 GTT coupe manual mettalic black.
135,xxxkms
With rego till 21 AUG 10
Heres just some of the mods and assessories included:
Nismo body kitted
Silver carbon Z-tune style bonnet
Apexi pod filter (with self made shield box)
HKS SSQV bov
3" Exforce exhaust silencer included
3" front and dump pipe
3" hi flow cat
Bendix ultimate brake pads all round
Pivot grounding stablizer kit
Oil cooler
Apexi turbo timer
Height and damper Adjustable suspensions (forgot what brand)
2 way pager alarm
Large heavy duty battery
Hid 8000K
Single din dvd player with 4" screen all in one
Alpine type S 12" sub
Sony 800w Mono block amp
Kicker splits
Alpine 6*9
Work Emotion XD9's Silver 17's wrapped with bridgestone potenza stretched rears.
Imported 2 yrs ago, first owner in Aus.
Its farely stock, never boosted, but has amazing power, good response, very quite, inspection welcomed.
Only problem is that someone keyed 2 pannels drivers door and front fender, but will be fixed upon purchase.
Its well taken care of, very clean, accident free, serviced every 5000kms with pentrite Sin oil, fueled with only BP ultimate.
Asking for $19,000 with road worthy.
Can be negotiated without rims.
PM if interested!
More pics taken soon...
https://www.sau.com.au/forums/topic/290096-fs-1998-skyline-r34gtt-coupe/
Rwc can be included depending on price, pretty much in road worthy condition. Just need front tierods replaced and new rear tyres, which ive got some continentals ready for it. I have already had a machanic do a road worthy inspection on the car last week.
NOTE: Potenza tyres on the rears have camber wear therefore will be changed to continentals for the purchaser. Continentals are german tyres quoted $450 per tyre at TTF.
As for swaps im interested in a jazz vti-s with 7k cash on top if anyone is interested in swaps, need to degrade to renovate the house.
I am definately not trying to ruin the market but the girlfriend is giving me the S*** for it. It must go guys. Must see to appreciate it. It is manual, turbo, coupe and it snaps heads. I dont think theres many out there cheaper!
Edited by cjlancer
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
