Hi All,
In my R33 Gtst I have an RB25/30 and I'm going to need to massage the firewall a little to fit the rear cylinder head oil drain fitting that I am using. Has anyone done this before that can share their experiences? Is there much behind the firewall in this position keeping in mind with the 3litre block its a 25mm or so higher than standard?. Its positioned in the rear top welsh plug spot that sits between the cams. (see sample pic)
Everyone's thoughts are welcome.
Cheers
Steve
hammer
only real option without taking the dash out completely to section the area and weld in a new piece. You cant introduce too much heat either as there is the firewall insulation on the inside.
hammer
Thanks
Yeah, thats the plan as it stands, but I suppose I trying to find out how much room I can make before I damage whatever is behind it.....
you will probably have less than an inch - just cant recall
have a look for the heater core DIY threads, should have pics of dash out as the only bits in that area is the heater/blower box
Thanks again, will look them up! I know I saved them as I need to do the heater solenoid when I can get the time. Shame your not in Melb, I have a fair bit of powder coating to be down once I finish installing the engine and redo all the ic pipes. I also need the cam covers done.
Cheers
there is always AUSpost if you cant get what you need locally :)
Biggest thing to what for is the mounting points for the heater units, there are a couple of mounts up there, but i cant recall exactly where.
there is always AUSpost if you cant get what you need locally :P
Ah, thats the pic. Thanks
Anyone else "massaged" their firewall?
  • 1 month later...
  • 1 month later...
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
