Very reluctant sale and thus priced to sell - no time wasters please...
Price: 18,500 o.n.o. (will consider all reasonable offers :( )
Note: Personalised Plates not included
Contact Details: PM or text/call 0410405000
Specs
*Low kms - only done 129k in 8 years
*Log Book serviced with all major servicing done at Subaru
*18 inch alloy wheels (original Subaru 17 inches is included in the sale)
*Lowered Suspension
*3 inch stainless steel cat back exhaust system
*JBL 1000 watts Subwoofer and Amp installed (included)
*NO MODS TO THE ENGINE*
*Throwing in Navman Satnav system with Navpix !
************************************PRICE UPDATE*******************************************
Ok i need this gone in 2 weeks.. so here's the deal.. the lowest price I have set is 15k.. any offers above 15k will be considered and i will arrange an inspection/test drive.
At the end of this month, this will be sold regardless as a trader has promised 15k..so be quick and make an offer.
swaps for my 04 hilux + 2g cash your way?
thanks for the offer mate! sorry i m not interested in a swap. need the whole cash and hence the sale..
Edited by myskyride
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
