Hi guys, ive just bought a R33 GTST S2 almost completely unmodified at the moment. Over the next month or so I will be doing the following mods:
- Induction kit, apexi pod already on order from sliding performance!
- Front mount intercooler
- Turbo back exhaust
- Tein superstreet coilovers
- Injectors
- Apexi Neo (already purchased)
- Installing remaining stereo gear; MbQuart Premium front speakers, head unit (already purchased)
- Nismo short shifter kit (already installed)
Any further advice on initial mods to include is much appreciated, I intend to use the car as a daily driver with the occasional track day,
Cheers
Rob
https://www.sau.com.au/forums/topic/291004-intro/
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
