As I have now stripped my car for sale I no longer need two sets of wheels so my extremely rare JDM Stich Rims are up for sale. The rims are 18x9" Fronts and 18x10" Rears complete with 235/40 front rubber and extremely sticky + expensive 265/35 Continental Contisport C1 Racing rubber on the rear.
Price - $1500ono
Location - Adelaide will courier at buyers expense
Contact - SMS 0404998591 or PM me
Edited by nigelswazi
what offset ? would they suit 32 gtr?
Offset is +38 on the rear will have to check the fronts when I get home but 10" + 38 would sit out 5mm more than R33 GTR wheels so would suit R32 GTR + perfect fitment on R33 GTS-T etc
http://www.1010tires.com/WheelOffsetCalculator.asp
wouldnt swap and some coin your way?
Sorry mate no need for other wheels as selling the car thanks for the offer tho.
These are back up for sale as I have had no contact from the inital buyer now
Fronts have 225/40 (sorry 235 was typo) Dunlop LeMans LM702 Rubber with excellent tread but do have camber wear
Rears have 265/35 Continental Contisport C1 Competition Rubber with 50-60% even tread left
Fronts are 9" + 38 / Rears are 10" +38 sat nice and aggressive on my R33 so would be even more aggressive on S13/R32/Cefiro etc
Can sell without the 265/35/18s on the back, still with the worn out 235/40/18 Dunlop LeMans LM702 on them, if buyers would prefer for $1350.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
