Hey everyone,
I have a 1500 watt 12'' Square Kicker sub, 750 watt Kicker Amp and a massive 200a fuse that ill give with it - for sale. Below are the specs, pics and prices. If anyone is interested give me a call or sms.
Sammy - 0410 495 592
Kicker 1500 watt 12'' Square Sub with insulated custom box (Model: Solo-Baric L7)
(RRP $659.00) $450.00
  • Size (IN, CM) - 12, 30.5
  • Impedance (OHMS) - 2 or 4 DVC
  • Max Rec Amplifier Power (WATTS PEAK/RMS) - 1500/750
  • Sensitivity (dB 1w/1m) - 88.6
  • Frequency Response (Hz) - 20-100
Kicker 750 watt mono block amp (Model: ZX750.1) (RRP $769.00) $550.00
  • mono subwoofer amplifier
  • 375 watts RMS x 1 at 4 ohms (750 watts x 1 at 2 ohms)
  • variable low-pass filter (50-200 Hz at 24 dB per octave)
  • variable bass boost (0-18 dB at 40 Hz)
  • subsonic filter (12 dB at 25 Hz)
  • wired remote bass level control
  • Class D design
  • speaker-level inputs
  • preamp outputs
  • fuse rating: 40A x 2
  • 4-gauge power and ground leads — wiring and hardware not included with amplifier but i am including a 200amp fuse with a 4-gauge power lead.
    Call or SMS if you are interested - Sammy 0410 495 592
    Willing to do both sold together in 1 sale for $900.00 for the lot
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
