Item: Nissan skyline 1996 S2
Item Condition: Great for age, but has some scratchs from old owner
Reason for Selling: was going to be my project but got new ideas.
Price and Payment Conditions: got to put a price so there you go 12000 mainly swaps
Extra Info:
1996 S2
Unfortuntly it is auto
56000km YES 56K
interior is mint condition
engines also well looked after
curently has R33 stocks on rear,and R32 stocks on front due to sellig the 20's.
rego till NSW FEB nxt year
Has Straight through exhaust so very loud
Lowerd front and back with king springs
clarioin Head unit
clarion front and rear speakers
and 2 subs in back but no amps.
comes with wing in the back seat
Pictures:
trying to upload
Contact Details: 0403717336, txt me or PM ill reply as fast as i can
https://www.sau.com.au/forums/topic/291505-r33-4door-p-plate/
thank god you sold those 20s,
put her up on boost cruising mate - might have more interst there, p platers are always looking for NA skylines
yeh man they went in the 1st week. she's already on boost lol cheerz
