Hi guys and girls,
I have a complete set of *BRAND NEW* DBA Street Series Slotted Rotors.
DBA908SR, DBA908SL, DBA909SR, DBA909SL.
To suit Nissan Skyline R32 GTS-T front and rear.
I bought a set to replace my stock ones but only ended up changing the brake pads so they are brand new in boxes that haven't even been opened.
RRP on these: Fronts $209ea and Rears $179ea
Asking price $680 for the set - may be prepared to sell as fronts and rears only.
Located on Sunshine Coast QLD - can post if needed and buyers expense.
PM me or leave a post on here.
Cheers
Kails :P
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
