Hey all,
Started cleaning out the garage tonight to finally make room for some cars to actually be worked on inside! More parts will be added this week, but for now:
Prefer pick up from Western Sydney but will post at your expense :banana:
Standard Air Box and aftermarket panel filter - $100 (no snorkel but as new condition) ** SOLD **
Standard Front Guard Side Indicators - $50
Nismo Radiator Cap used once - $40 **Sold**
Cusco Rear Strut Brace - $170 (near perfect condition) ** SOLD **
Starter Motor - $75 ** SOLD**
Series one fibreglass eyelids - $50 (never fitted or painted) **SOLD**
Series 1 headlights (from a 4dr so chrome inserts) $250 **SOLD**
RB25 Turbo elbow and a bit of piping - $75
Standard Rb25 BOV - $50
PM or post in thread :blink:
https://www.sau.com.au/forums/topic/291717-r33-series-1-gtst-parts/
hi there where abouts u located???
i'm interested in the radiator cap if u still have it.....
thanks!
Hi ... pickup is from Toongabbie after hours (or I am home today and tomorrow) otherwise Wetherill Park during business hours
Cheers
Anna
EDIT: Yep sorry all still available :P
just wondering how come ur selling the cap???
also r u able to post to melbourne? n how much???
thanks
matt
Put it on the car 2 years ago, motor blew up same day.... lost it in the pile of car parts, found it last night :P
I am selling my car too... and a nismo radiator cap isn't going to be the deal breaker on that one!!!
Yep I can post - Say $50 posted express - $45 posted snail mail.
Cheers
how much for the brace posted to vic 3173?
Say $185.. would need to be by pack and send or fastways as I am pretty sure it's too long for Australia Post!
Wouldnt happen to know if the brace would fit a 34??
Nope, just double checked the part numbers and they are different for the rear. The front is the same I believe though.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
