Hey guys and girls
For sale I have a pair of GENUINE DMAX 25mm widebody front guards.
Have had them fitted to my 32 but decided I wanted to go stock kit instead.
Will have pics posted up hopefully by the end of the day. :D
$250 for the pair.
Located on the Sunshine Coast
Pm me or post on here
Cheers
Kails
hey there can we get some pics?
r u wiling to post to sydney?
if so how much to postcode 2176?
will get a price for you to sydney am willing to post for sure :) i will post some pics up later tonight
cheers
kails
they dont even look like they fit properly? and im assuming this +25mm is for gts gaurds not gtr gaurds?
these are genuine dmax they do fit properly and they fit all 32's but why would you put +25 on a gtr anyways coz they are already pumped stock :D
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
