$50 + postage
or pickup for $50 *Melbourne 3150*
genuine leather momo wheel, could use a recondition of for a driver with gloves *lol*??
anyway, pics.
http://img193.imageshack.us/gal.php?g=dsc01520e.jpg
Cheers
Alex
contact either here, or on 0422 017 404
https://www.sau.com.au/forums/topic/292362-fs-momo-wheel/
must be my eyes but from the pics doesnt look too bad, in that it doesnt look ripped or anything. how bad is it actually, i understand its only 50 bucks so cant be too good but just wana know how worn it is?
its not horrible there are no major rips, i dont think there are any rips really.there are 2 slight holes in the right hand side of the wheel, not rips thought just where its worn through the leather i believe. Other than that its in good nick..
If u weren't happy with the condition the wheel was in id refund the money, but it is $50 soo... yeah its not PERFECT but its great for $50.
https://www.sau.com.au/forums/topic/292362-fs-momo-wheel/#findComment-4896235
