i have just put my r33 gtst back together after blowing up 6 years ago. anyway connected everything and tried to start it. car turns over but will not fire. doesn't even sound like it's goin to fire. i pulled a coil out and put a spark plug in it wound the car over and no spark. as soon as i stopped winding the car over it sparked. any ideas would be great. has microtech
https://www.sau.com.au/forums/topic/292511-r33-gtst-wont-start/
thanks guys. i think it is the cas. tested it yesterday and seems to be stuffed. the problem i have now is i have had 2 motors and not sure wat this cas was of. when ordering one they say there is to different types and need the number off the cas. does anyone no if it matters which one i get
ok replaced cas. now i am getting spark. car still will not start. checked fuel, i am getting fuel up to the fuel rail but doesn;t seem like im getting fuel in the engine. really any help would be great. do i need to reset codes etc
ok so after putting jumper cables on it and rotating cas while cranking it fired ran for like 5 seconds then died, problem is it kept doin that its got bosch 040 and malpassi but issue is microtech is locked and dunno now if its fuel or the ecu causing it. gonna change fuel filter and do a fuel flow test to see if its kepping up fuel does any1 have any other suggestions or ides?
check all wiring to coils and wiring is ok now i believe its the michrotech cos its locked cannot do anything with it if i remember correctly i had the same issue with it 6 yrs ago when it locked up had to send it away to have it reset.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
