Hey.
0409 593 100
Gazelle s12 driver's seat. Old, doesnt provide the best support but works fine. $15
http://members.optusnet.com.au/downing001/24102009284.jpg
R32 GTS4 Passenger seat. Good condition, works well - Great upgrade for your girlfriend, she'll love the lush velour and improved lumber support. haha. Remember though, that as this came out of a 4 door, it doesn't bend forward past 45degrees so not the best for a 2 door unless your drivers side will be used to get passengers into the back. $25
http://members.optusnet.com.au/downing001/24102009283.jpg
s13 COILOVERS: $300 (Full Set)
Apexi WS World Sport N1 DAMPER.
I bought these second hand just to get me through a couple of month while rebuilding my other set. Only paid 600 for the full set. The ar$ehole seller insisted they were in perfect condition but it soon turned out the fronts are shagged. The front driver's side knocks and leaks. Passenger side seemed OK and I never installed the rears so don't know. However the rear's look OK and there is no side of leakage of anything dodge.
Fronts good for parts (or rebuild if possible?), rear's worth using again. Very stiff springs when they were installed, no idea how many kg's though.
Will sell the rears for $220 and fronts for $120.
FULL SET: $300.
http://members.optusnet.com.au/downing001/24102009281.jpg
10ml Spacers for s12. - $25
http://members.optusnet.com.au/downing001/24102009282.jpg
Random BMX - $20
Puncture in back tyre. I replaced the tube but it popped again, must be something inside of wheel making poppy pop pop.
Works OK otherwise.
http://members.optusnet.com.au/downing001/24102009287.jpg
Call me on 0409 593 100 preferably on the weekend or after business hours but text anytime and I call you back when I'm free.
Pick up North Bondi Sydney.
Cheers,
Nick.
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
