Howdy,
Nice and simple. 2 things for sale PICK UP ONLY from Hornsby area in Sydney.
1. R32 GTR Seats w/rails - **SOLD**
2. R32 GTR Rims w/ RE55's - **SOLD**
Please feel free to contact me via PM or here
First come with moula gets the goods
Cheers,
Ando
https://www.sau.com.au/forums/topic/294100-sold/
