Here we have an S13 with a 5 speed manual turbo 1.8l engine. Engine was given a freshen up about 18 months ago with acl rings, bearings and mls headgasket. At the same time all seals, gaskets and clutch kit were done. It has a garrett t28bb turbo which blows no smoke with an intercooler kit and a 3in exhaust with a varex rear muffler. It has also had new radiator and heater hoses and a kit in the clutch slave and master cylinders. Engine has bosch coil conversion and is running 10psi boost there are also sports shockers fitted in the standard struts. Has 17inch speedy wheels with good tread and new brake pads. Inside has a full stereeo system, cruise control, climate control with ac that works, turbo timer, boost gauge. All electrics work fine and there is no rust around the sunroof, has tinted windows and a full alarm system with remote entry. The body has a few minor dents and scratches and the seats have come appart at the stitching but are still comfortable to sit in. Car is driven daily and is serviced every 5000km. Has not missed a beat in the 18months I have had the car on the road. Bought a new project so it has to go. Contact me for more info I am sure there are some small things I have missed. Asking $7500 and located in Murray Bridge SA. 0439379759.
Edited by bradr8
https://www.sau.com.au/forums/topic/294343-fs/
  • 3 weeks later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
