Wow Ivan, you have some guts if you want to start grid racing straight up...It's a pretty nerve racking experience first time off..Not sure you are understanding the difference between proper door to door racing or just peddling a car around the track as fast as you can go!
There are club level race series that you would be able to get involve in....The main cost like the guys are saying is your car..
There is also licencing, logbook, racing apparel and most door to door racing requires the car to have a full roll cage so would be hard to have a steet driven car that you race..I reckon if that was the way you wanted to go
Maybe check out a few race and go kart days and have a chat to people/entrants and see if you can make your mind up which way to go..
Even super sprinting a car is loads of fun without the stress of guarding your position and line.
It's an expensive hobby but I wouldnt have it any other way :)
https://www.sau.com.au/forums/topic/294667-racer/page/2/#findComment-4920793
  • 3 weeks later...
motorsport is easy. just choose the right parents (ie enough money to pay your way throught the first 5-10 years).
sorry to say but the best drivers (ie most talented ones) are no-where near the top race categories internationally. they are working at maccas or something. you need money to race cars no matter how you do it.
I am lucky enough to earn enough to race sometimes, and due to sticking with it over the years I get about 20% of my total costs paid by various businesses (almost always in the form of discounts, not cash payments). I'm sure every single person on SAU pays between 80-100% of their total racing budget.
having said all that...you can still race without spending too much. you just need to stay within your budget and not do anything silly like borrow money to race. the best thing you can do is get together with some mates and work together to keep costs down and learn. pick easy stuff like improved production (cheapest is to buy a pre-bult car) and supersprints/hillclimbs.
but don't kid yourself. even at a state level, buying a race winning car will cost $50k-200k. tyres will be $2k a set, and you need new ones every single round if you want to win. entry fee for a state round is $500 + accomodation/crew/food/fuel. national rounds budget $2-5k each round + transport.
https://www.sau.com.au/forums/topic/294667-racer/page/2/#findComment-4949033
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
