KBEE coilovers for r32.
BRAND NEW, in box with papers spanners etc.
excellent quality coilovers. fully adjustable, think there 15 stage damper adjustment. 8/6 spring rate
same as HSD hr coilover(1700 new) but these are valved in japan not korea.
$1350
or
cusco r32 coilovers
zero 1, 10k km on them.
mint condition. base height and spring adjustable. not damper adjustable
feel like 10/8 but told 8/6
in my car atm. will keep what ever set doesnt sell
$1300
s13/r32 castor rods
very low km nolothane bushes.
$70
r32 front upper arms
with almost new nolothane offset bushes to adjust camber.
$120
TEIN CASTOR RODS
$200
suit s13/r32 etc
very good nick
s14 castor rods
unknown japaneese brand.
really thick
think there jic
$200
S14 stockies
pair only
very good nick
have tread, 1 tyres blown out on one side
$70
r32 stockies
painted black
very good nick
$130
volk se37 wheels
very light weight, japaneese racing wheels. 5x 114
you will lose ur shit when u pick them up and feel the weight, its rediculous
17x8.5
17x 9.5
unknown offsets but i have photos of fitment. sit very well on r32
in very good nick, couple light spots of rash.
$1400 no tyres. postage 150 extra
CUSCO s14 rear camber arms $300
toe arms, think there cusco but not 100% $180
nismo 550cc injectors
top fed x6 for rb20/26 etc
excellent working nick. removed w/o any problems
$650
s13 carbon fibre dash cluster cover
not genuine cf but looks very real, not cheap by any means.
$100
trust r32/s13 struts
in great nick. no probs, lower car from standard. nice firm ride
$150
nismo rocker arm stoppers.
for sr20det
used but in excellent nick.
$60
rear 5 stud conversion with gtr rear brakes ive been told. good pads and rotors
$400
stripping out a regoed r32 4 door so any parts just ask
all items here are in great working nick, will add up a couple more things over the next couple days.
hey mate itersed in the upper 32 arms ....how do u adjust the camber with them?
you can see in this photo that the centre section has an offset hole, this can be rotated to either lenghten or shorted the mounting position of the arm and thus changing the camber.
let me know.
catchya
They do +/- 1 degree, these do better with grease nipples too (just stops em from squeeking) but will work just as good in current form. Good kit I have them in my 32R
r32 stockies still there? whats your location.. cant seem to see it
car is rb20det auto, new water pump and timing belt on motor.
located in adelaide SA
Edited by flame_this
have a few sets of castor rods here ranging from $200-230 depending on how newer conditon u were after.
all in good working nick.
have both cusco and tein sets available.
Greddy profec b spec 2 boost controller
as new condition
$400 firm
i used only for a about a month. no box or instructions included though.
tein/ cusco castor rods s13 r32 etc
230 firm
excellent nick
tein castor rods s13 r32 etc
great nick
$200 firm
s14 castor rods
think there jic
$200 ono, came from a jap drift car. really thick
cusco r32 front strut brace
bought it been told it was a rear but it was a front
$90
s14/r33 toe arms think there cusco
$180
great nick
s14/r33 camber arms cusco
$300
great nick
trust struts were about 20-30mm shorter than standard
nardi steering wheel
classic 360mm
$200
minor wear on top rhs corner, otherwise good nic. comes with horn
rb20det
genuine 70k km
removing from my car next month due to sr conversion
apexi power fc + h/c
hks 2530 turbo
braided lines
gtr injectors
os giken adjustable camgears
splitfire coilopacks
good nick.
will do a compression test for buyer
rb20det CHEAP!!!!!!!
from auto r32
come complete
$1400 with everything needed, loom computer everything
these are the 200$ castor rods as mentioned above
all in good nick
just want to clear out all my stuff before i strip my car out next month. offers are welcome but dont be un realistic
mackie
0422 905 956
compared the two struts today.
the trust ones were about 3cm shorter than the standard ones.
r32 castor rods sold
r32 front camber arms sold
sr20 ras sold
s14 stockies sold
still heaps up for grabs.
also have a
classic nardi steering wheel
$200
slight wear on top rhs, comes with horn. good nick otherwise
taking out my
RB20 det motor from my r32 in the next month
in good nick, 70k genuine km
os giken adjustable cam gears.
new timing belt and water pump
gtr injectors
power fc with handcontroller
hks 2530
split fire coilopacks
braided lines
3'dump/front pipe
cross member
still in car running, doing an sr conversion. no problems at all
also stripping out an rb20det 4 door
rhs panels good nick
good nick rb20det
comes complete
cheers
  • 1 month later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
