1996 Silver R33 GTS-t
90 000km on odometer.
First complied in December 2007, first registered (NSW) January 2008.
I have Owned the car Since January 2008, The car has never attracted police attention. It has a GTR Front bar with genuwine GTR front indicators,
Since I have owned it the car has been serviced every 5000km (receipts) with ELF motor oil.
Mods include a new EXEDY HD clutch (receipts)
Full Fujitsubo Turbo back exhaust (3 inch turbo - cat, 3.5 inch cat back) receipts
Apexi pod filter (receipts)
JJR Stealth Front mount Intercooler (receipts)
JJR front strut mount (receipts)
Genuwine Nissan rear strut mount
Window Tint from Solar Tint Castle Hill (receipt)
DIN cluster Boost, Oil and Water temperature gauges (receipts)
Pioneer CD player (with wires for sub connections) (receipts)
AVS GTR look alike wheels
New Tyres bought from SAU NSW (Federal 595) Front 135/40r17 Rear 145/40r17
Rhino Alarm/immobiliser Australian standards (insurance aproved) with built in turbo timer, keyless entry.
Car runs very well, never missed a beat, starts on cold mornings no problem, always let car warm up for 5 minutes on cold engine, With these mods the car hit 191rwkw on a SAU NSW dyno day, have not seen another r33 gtst with those mods hit that power, print off to prove it. Paint is in as new condition.
I don't know how the car was treated in Japan, but it is a straight car, the engine power results prove that the engine is fresh, never had any mechanical problems over the 2 years i've owned the car.
https://www.sau.com.au/forums/topic/295044-r33-gts-t-series-2-manual-sydney/
  • 3 weeks later...
New NGK platinums and Splitfire coils put in it, save yourself $1000 of maintenance with this car
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
