Hey guys, I am having some trouble trying to set up my laptop to connect to the net via my wireless router. I can access the net when I plug the laptop straight into the modem, but when I plug the modem into the router, and then into the laptop - no go.
I am not getting the internet light lit up on the router, so I only get a local connection. I am wondering is there some configuration I need to do, or is there an IP address issue?
Any help would be appreciated, if you need more info just ask and I'll try and find it!
Thanks - Jase
https://www.sau.com.au/forums/topic/295712-connecting-a-wireless-router/
You will need to do some setting I would have thought.
Try login into your router with IE. Type 192.168.1.1 to access it. Normally login is admin and password is admin by default. You should change the password asap. When you're in, have a poke around, it shouldnt be too hard.
So you connection is telephone line->modem->router->laptop?
1st make sure that the connections are correct then set your modem to bridge mode 1st then do the set up on router (the wizard setup where you enter the user name & password for your ISP).
Go into your router and turn off DHCP and leave it turned on on the modem... Often if both devices have DHCP turned on they are both trying to assign everyone's IP addy's and conflict... this is a common problem
2nd Go into your router and check your settings for your wireless... make sure its turned on etc =P
Model numbers specifically (for the Belkin Router)
Sounds to me like you don't even need the modem.
There is little point in running a router and modem, i cannot think of any use for it in a home setting.
He might not need the router.. but if he is not into modem/router configs the OEM settings from is ISP on his modem would best be left as it and just have it assign IP's and serve the internet to the router which does all the networking...
Oh, you've bought a standard router *and* a separate modem.
What most people do is buy an ADSL router OR a cable modem router.
I bought a Billion 7300G from MSY which does ASDL2, wireless and 4 port routing.
I can't think of an easy way to do router + modem unless you connect your modem to the computer, your computer to the router, and allow other computers to connect through that modem when the computer is running....
Or he got the modem free...
Let us know how you went Jase with the DHCP settings.... most of the time if a modem and router are in the same network the only reason they dont work together is because they are both trying to act gateway and IP assigner...
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
