people actually care about spelling?? wtf
seriously who gives a shit...
sorry wrote this in a rush as i was walking out didnt realize i didnt mention the problem =]
i can shift into all gears with the engine running without even putting the clutch in but the cars doesnt move nuddaz
by the way i dont drive a 33...
Yes because we are Adults we do care about spelling
check your propeller shaft is spinning whilst car is in gear and eliminate things from there .
If prop shaft spins it will probably be diff or rear axles snapped
If it does not spin it could be the main shaft or idler shaft in gearbox
huh? now im more confused
OK, my bad, I just read some more of your posts, and you drive an R32?
Dude, wtf ?
Mods should really just delete this entire bad example of a thread before a cop reads it.
yeh bro algee
but yes 32 it is
honestly i really dont know a whole lot about these hence why im probably asking stupid crap haha
would a r32 gtr box fit in or is the bell housing a different size? or is the box completely different as a gtr is awd?
cheers mahn
completely different. jack up the back of your car, put it in gear and let it idle, have a look under to see if the tailshaft is spinning, if it is, see if your halfshafts are spinning.
haha quite funny fellas but i think thats next week.
i see you have nothing better to do then post stupid SHIT on the net ae
but seriously i asked for advise not grown people trying to act like kids and be funny if i wanted that i would go watch the wiggles
Edited by SEEYOUBYE
SAUWA isnt known for intelligence or maturity to start with but I think their response is more so a cold shoulder because you admit you f**ked something up while being an idiot. You've been told what to check, have you done that yet man ?
ffs your goddamn car isn't moving. FIND OUT WHAT IS WRONG instead of asking what's wrong. because unless you want these dumbc*nts to come round to your house and look at your car for you, and probably steal all your shit in the process, only to leave having even less of an idea of what is broken on your car, with a strange feeling lingering like you've just been arse-f**ked with the hot air from their gobs, i suggest you jump under your car, chuck it in gear with the engine running and see if the tailshaft is spinning.
Edited by Dorigecko
wut?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
