Brand new in box never installed EMS ecu , didnt use computer because i got messed around with the tuner so used ecu i had in car already .Paid $1400 new 5 months ago
Location ; Blacktown , Sydney West
Price $900
Contact Mark ; 0433 997 667
https://www.sau.com.au/forums/topic/296297-new-ems-stinger-ecu-for-r33-gtst/
