Im selling my my bmw, just bought another skyline and this is taking up space in my garage so has to go.
This is a unique Euro Styled BMW, Drives Great and is a real head turner!
E30 BMW 1.8ltr 2door
5speed Manual
237xxx kms
Gold
Modifications done are as follows.
Mtech 1 front bar
Mtech 1 Steering Wheel
16x8 +0 Sports Max Deep Dish black centre rims
Mirror Tinted Windows
Light aircraft high beams
Black & White Seat Covers
Monroe shocks all round and king springs (low front/superlow rear) Only Installed under a month ago! Also comes with Brand me in box Super Lows for the front!
2" straight through exhaust with single rear muffler
Lightning Audio 12" Sub in custom made boc
MBquart speakers all round (6.5" fronts, 6" rears)
Soundstream mono block amp
Lightning audio 4 channel amp with capacitor
This car is a dream to drive and looks Great!
all work has been carried out by BMW specialist at Percat, with no expense spared.
Price $5500 ono
Thanks, if your interested you can call or txt anytime on 0432 581 798 or reply to this thread.
Lewis
https://www.sau.com.au/forums/topic/296903-e30-bmw/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
