hey all
im looking to buy a BOV, but unsure how i am to fit it to my r34 Gtt
i contacted turbosmart, they said they dnt make an adapter for the r34's
any ideas? are the r33's similar? maybe an adapter to suit?
i feel like this is a noob question, but just looking for a quick reply
cheers
https://www.sau.com.au/forums/topic/297017-turbosmart-bov-on-r34/
