Parts list and prices
Whiteline Heavy Duty Front Swaybar BRAND NEW BNF24Z. Fits ALL model R33s including NAs except GTS4s and GTRs. $200
Whiteline Rear Upper Control Control Arm Bushes BRAND NEW W0579, $70ono Fits r32, r33, r34, 180sx, ceferio, etc
Whiteline Rear control arm caster adj. bushes BRAND NEW, not sure what car there for but part number is KCA337. $70ono
R32 GTS4, R33 GTS4, Stagea Front swaybar $20
R32 GTS4, R33 GTS4, Stagea Rear swaybar $20
post-40593-1258768364_thumb.jpg post-40593-1258768396_thumb.jpg post-40593-1258768489_thumb.jpg
R33 GTS4 stock shocks w/ aftermarket springs, Shocks are in ok condition, no signs of leaks. As for springs there in good condition just not 100% which brands they are, being red, either pedders, nismo or apexi springs?. They might be pedders but I can't tell. Fits R32 GTS4, R33 GTS4, GTS(25), GTST. $200ono
Genuine Momo Steering wheel. Typ D35 KBA 70116 is the model. In excellent condition, only very minor wear marks. $170ono
RB20/RB25 Crossover pipe in good condition - $20
Gates Timing belt used 10,000kms only $45ono
R33 GTR INTERIOR
R33 GTR Centre Console compartment (compartment bit behind gear boot). Excellent condition, no damages whatsoever. $50
R33 GTR Full Interior panels 2xFront 2xRear. Great condition, no marks, no scratches, no tears. $150
R33 Climate control unit. In good working order no damage. $50
R33 Front and Rear Seat Belt sets, Good condition was working perfect when removed. $150
post-40593-1258768951_thumb.jpg post-40593-1258769012_thumb.jpg post-40593-1258769050_thumb.jpg post-40593-1258769121_thumb.jpg
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $150ono
Stainless steel Cannon Muffler Angle Cut Tip - 2.5'' Inlet, 5.5'' Barrel, 4.5'' Angle cut Tip
Very good condition no dents, came off R33 $40ono
R33 Series 2 VCT N/A Motor RB25DE 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. PRICE DROP TO $550ono take it now or it goes to my friend soon. Includes 4WD Sump and Front Diff and shaft, wiring loom and ecu iridium plugs, exhaust manifold and intake pipe. Can also be used in RWD application, just swap sump with a RWD sump.
NOTE: Took off some parts as I needed them. These include, water pump, tensioner and idle bearings, harmonic balancer, A/C and pwr/steer pump, so just pretty much 100,000km kit.
R33 GTS4/GTR Series 2 4WD Gearbox will fit stageas as well as any other running 4wd gear including GTRs. 114,000kms in good working condition, however 4th started to slightly crunch after I had oil changed too thin, needs thicker oil and will be ok.
$400ono
RB25 Flywheel, Factory in good condition fits RB20 as well. $45
LOCATED IN SYDNEY, WILL POST BUT BUYER PAYS FREIGHT. 0412 297 325
Parts list and price drops Update
Whiteline Rear Upper Control Control Arm Bushes BRAND NEW W0579, $60ono Fits r32, r33, r34, 180sx, ceferio, etc
Whiteline Rear control arm caster adj. bushes BRAND NEW, not sure what car there for but part number is KCA337. $60ono
R33 GTS4 stock shocks w/ aftermarket springs, Shocks are in ok condition, no signs of leaks. As for springs there in good condition just not 100% which brands they are, being red, either pedders, nismo or apexi springs?. They might be pedders but I can't tell. Fits R32 GTS4, R33 GTS4, GTS(25), GTST. $190ono
Gates Timing belt used 10,000kms only $40ono
R33 GTR INTERIOR
R33 GTR Centre Console compartment (compartment bit behind gear boot). Excellent condition, no damages whatsoever. $50ono
R33 GTR Full Interior panels 2xFront 2xRear. Great condition, no marks, no scratches, no tears. $150ono
R33 Front and Rear Seat Belt sets, Good condition was working perfect when removed. $150ono
R33 GTR Front 5 Stud Hub Assembly good for 5stud conversions $145ono
R33 Series 2 VCT N/A Motor RB25DE 147kw, 114,000kms motor is in A1 condition, regularly serviced synthetic oils. Only pulled out for conversion. PRICE DROP TO $500ono take it now or it goes to my friend soon. Includes 4WD Sump and Front Diff and shaft, wiring loom and ecu iridium plugs, exhaust manifold and intake pipe. Can also be used in RWD application, just swap sump with a RWD sump.
$385ono
R33 S2 NA ECU great working condition - $140
STAGEA S1 ECU great working condition - $140
CONTACT NUMBER 0412 297 325 located in sydney.
Edited by OoskylineoO
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
