So i'm thinking if swapping out the already good speakers for hopefully something better. I have no idea what the wattage of the factory speakers are. From this site I have learnt the size of the front and rear. Anyway take a look below at what I am thinking of using.
http://www.amazon.com/exec/obidos/tg/detai...F8&v=glance front
or
http://www.amazon.com/Polk-Audio-6-5-Inch-...d_bxgy_e_text_b
http://www.amazon.com/Polk-Audio-5-25-Inch...4733&sr=1-2
and MAYBE
http://www.amazon.com/Boss-BASS600-Low-Pro...5206&sr=1-5
I'm sorry if this is a stupid thread. But i would like a lil help. If anyone cares to share their audio set up. And if you also know the wattage of the factory speakers.
https://www.sau.com.au/forums/topic/297221-am-i-downgrading-my-sound/
you should try read more on G35driver.com in Audio section.
There are alot of people happy with just changing out the stock speakers to infinity one with 4 ohm. As our stock speakers is taking in 4 ohm instead 2 ohm on most aftermarket speakers.
your Polk Audio DB651 seems ok for the front, but please read more on the site i gave you to confirm. Btw is yours a Bose or not?
Edited by pw350gt
just curious, what's the reason most aftermarket chooses 2ohm ? are less resistance result to more powerful sound ?
what would happen if putting 2ohm speaker system on a factory's amp that feeds to oem 4ohm speakers? will it overload or underload?
well my car was bought used and it didn have the factory system in it. It has like an after market cd player... it has the tv screen tho. Should I take a picture? Thanx anyway I'll check the g35 site
All i know is that the lower the Ohm (2ohm or 1 Ohm) will create a more powerful sound, but less clarity hence the subwoofer. Therefore the Higher the Ohm are (4ohm or 8 ohm) will have much more clarity. Usually the 6.5" drive is to create a good mid bass therefore the 2 ohm is usefull for it, as the treble is created from the component tweeter.
I'm not 100% an audiophile, but i think that's what it is from what i learned. Please correct me if i'm wrong.
Home audio is 8Ohm, Generally car audio speakers are 4Ohm, I don't know where you guys got the idea it's 2Ohm.
Some subs, in particular dual voice coils, are 2ohm so can be wired in series to make 4 Ohm or wired parallel to make 1Ohm.
There are benefits and drawbacks for each, lower Ohmage draws more power output from the amplifier if the amp is capable of running lower ohmage. The downside is sound quality is reduced. Some would say that is not so crucial at lower frequencies BUT I certainly wouldn't be going less than 4ohm on your component ( front) speakers.
P.S. The speakers you've linked to are coax. In laymans terms the tweeter is mounted WITH the midbass driver. You want a component set where the midbass and tweeter are separate items. If the 250GT is the same as the 350GT then the factory locations are Midbass in the door and tweeter in the sail panel (behind the door mirror).
LOL even more reason to upgrade :D I don't have factory speakers so can't pass judgement on them but at 1ohm the sound quality would have to suffer immensely.
I'd normally assume the midbass & tweeters have HP/LP caps and are wired in series to present a 4ohm load to the amp, If not then the factory amp is an impressive little kit to be able to load down to 1ohm :)
for what it is the average punter is happy. for the SQ nuts it sux. the doors are paralled with a cap on the tweeter. I have a spare amp here and have yet to take the top off it. its an all alloy item though the size of a VERY thick book.
there is a removal guide for the radio posted in the audio section of this forum.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
