Hey guys. A couple of month back I had a problem with my exhaust sounding like a tin can with a bunch of rocks in it. It ended up being the muffler being busted and so I got a new one put on. For a week there was no problem with the new muffler but now the muffler is going AWOL on me..... again!
For a starter, my new muffler gets louder as I drive along. What I mean by that is that when I got the muffler first put on, it sounded nice and smooth like it should any time, all of the time. Now, when I first drive my car, it sounds smooth like it was originally but as I get more and more into my journey, my exhaust gets louder, especially if I've given it some gas. Now obviously I thought there was a leak in my exhaust, like a hole somewhere on it, but then why wouldn't it just sound the same all of the time and not get louder only as I drive?
Secondly, after a trip on the freeway for approx. 3km or more sitting on 100, my exhaust starts to make a, I don't really know how to explain it, reverberating? sound. Like I can hear the exhaust reverberate more and more as I drive along on the freeway. Then when I finally get off the freeway and stop, when I take off again, there is this huge rattling/vibrating noise coming off my exhaust. But this noise and rattle/vibration ONLY comes after I've been on the freeway.
So what the crap is wrong with my exhaust!?!? I know I should take it back to the exhaust place, and I will, but I just need some help deducing what the hell the problem is because it's sort of hard to 'show' the guy what the problem is since it only happens on certain occasions.
Thanks for all your help!
BTW, I have checked the cat and it's still intact so thats not the problem.
https://www.sau.com.au/forums/topic/297246-exhaust-problem-part-ii/
Build of up carbon generally makes a new exhaust sound louder and deeper....
So it's natural for my exhaust to do what I stated above? Because initially I thought oh it's probably the exhaust just wearing in a little and getting louder, but then what's with the freeway problem?
Cheers.
Re-reading it have you checked the backbox to see if the honeycomb muffler bit inside isnt loose mine was and i just puttied it up....
But for the exhaust yeah its pretty normal to get louder (not silly loud just a differant tone) its just teh build up of crabon on fresh steel.
Well if the honeycomb inside the muffler is loose then I'm just going to go to the exhaust shop and demand a new one. It's only been on the car for 3 wks tops and if it's already loose, then it's obviously faulty.
Cheers.
Any other suggestion or ideas?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
