hey guys i need some help im looking at putting a t51r with a .91rear housing its for a wrx that is now 2.6 ltr. i thought i would come over here and ask the skyline boys as i dont have any experience with these tubos.
the current engine set up is
wet sleeved 2.6ltr block
mahle pistons
par 1500hp rods
acl race bearings
2.5 crank
o-ringed block and heads
copper head gaskets
14mm headstuds
ported heads
1mm o/s inlet and exsurst valves
brian crower springs
wade 300deg cams
extractors
indy blue injectors
2x044 pumps
half inch fuel lines
ect list goes on
fuel - e85
the curent turbo i have is a gt35/66r it has 66mm front wheel, .80 front cover and a 1.06 rear housing and this turbo is to small and is on full boost just after 4000rpm but the the turbo has now spun the blade on the sharft and stuffed the front blade bent the sharft and stuffed the front bearing in it. and its going to cost 1200 to fix it, the turbo has now even done 200kms
so i was looking at a garrett t51r with a .91 rear housing do you guys think this will be to laggy on my set up ? im not to worred if it is abit because im running a nitrous kit as well
and i forgot to mention it has a built auto in it now with a 4,200 stall coverter
your help would be appreciated alot.
cheers
Edited by Lee586
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/
From the research etc. that we have done and advice given by people in the industry, the 0.91 rear will be laggier than the 1.01 or 1.05 rear due to it's TV (T6) flange which causes a huge pressure drop before entering the turbine. You are better off with the 1.01 rear that has a T4 flange. Considering there are none available or none have been sold in Australia, your options would be to buy it from the states or get the TA (1.05 A/R) rear milled to the T4 bolt pattern as they are only a mm or so different in their bolt pattern.
I would expect to see 1 bar of boost on the 1.01 rear at approx 5000rpm on a built EJ @ 2.6L.
And where did you get a GT3566R? Never heard of or seen one. I think you are probably referring to a GT3582R. Garrett don't make a compressor with an exducer of 66mm. that would be almost like taking the compressor off the GT3582 and putting one on from a GT2871....but smaller
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950550
thanks for your help the t51r i was going to buy from turbologic he said it was a t4 flage witht he .91 rear so im not sure, the 66r i have was custom built by gcg it uses the same shafts and rear blade as the 35r but the front wheel is 66mm and has a .80 front cover with a 1.06 t3 rear housing
when looking for turbos it gets compacated the guy said he can only get the t51r in a .91 and a 1.05 rear housing with a t4 flange
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950574
No, the GT51R comes in a 0.91 T6 (TV Flange) 1.01 T4 or 1.05 TA Flange. It also comes in others but not sure on those. I could find out if you really wanted the info on the bigger sizes.
The GCG turbo you are talking about is probably a T04Z compressor on the GT35R core. Very inefficient.
And Garrett would call it a GT3584R because it's the exducer that determines the last two digits. GCG like to be backwards.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950596
yeah they recon it was a to4z equverlent but it was really inerficent like you said, the turbo it a complete pieace of shit in my opinion.
what other turbos would you recomend for me as soming that might get decent boost around 4,800-5000.
i was also looking at the turbonetics gtk1000 it has a 76front blade 68rear blade with a .96 t4 rear housing
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950615
How much hp are you chasing is probably the more appropriate question?
If you want 600-700hp at the wheels then pick a GT3788 or GT4088. You should see 1 bar at 3800-4000 on the 37 and about 4200-4500 on the 40. If you want 700-800hp then you will need minimum GT42 or above. Things start to get complicated after that and a lot of questions need to be asked.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4950627
the auto draged about 50kw off at the wheels but i want about 400kw@wheels with the auto, and need somthing effecent enough to run 35psi
then will put a 150hp shot of nitrous ontop of that so there is a big chance it could go 500kw
we made 411rwkw with a cheap GT40 (v band rear 1.0) ($1300) through an auto on a1jz (2.5litre) at 22psi.
https://www.sau.com.au/forums/topic/297324-turbo-help-t51r/#findComment-4951896
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
