ok i have no idea of there offsets but if i measure against phils loaner rim fit ment they are:
18x9.5+5
18x10or10.5-0 ish
trial fits welcome
heres pics on how they fir the 4door with wide body front and stock rear guards..
so i'm told there worth a bomb to me there worth bout 2.3k 2.5k with new tires???
open to all trades and offers
location sydney northern beachs
pm or txt 0422984612
https://www.sau.com.au/forums/topic/297454-simmons-18s/
roy you should get a quote to have the centers machined there by making the offsets more guard friendly... personally i'd just pole the guards and cambe the wheels a tiny bit and they'd fit i just don't like the rims not my style
https://www.sau.com.au/forums/topic/297454-simmons-18s/#findComment-4953975
simmons arent made anymore, this set could easily get $4k on ebay.
if these were 17s, i would of bought them already... 18s too much to drift on :P
but i so want them... bad. lol
https://www.sau.com.au/forums/topic/297454-simmons-18s/#findComment-4954231
just wondering if these would fit a gtt with rolled guards front and rear and camber arms?
has anyone fitted similar to a gtt or does anyone have pics of a gtt with rims with roughly the same size.
cheers
kyle
https://www.sau.com.au/forums/topic/297454-simmons-18s/#findComment-4956613
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
