i have for sale a series one r33 gtst boot lid and series 1 spoiler $150 will need a paint to suit the colour of your car currently is wine red and the clear is peeling of the boot lid but not the spoiler
stock side mount intercooler no pipes $30 each x2
stock r33 sway bars dont know what there worth make an offer
big oval muffler5 inch tip 3 inch inlet $90
2 stock cat one with the centre bash out make an offer
r33 stock wastegate $50
or swap for a stock turbo plz i need one
PLUS is anyone interested in swap a ducktail/stealth spoiler for a series 2 and series 1 wing let me know cause i really want a stealth spoiler
parts are on brisbane southside
Edited by Turbo 33
https://www.sau.com.au/forums/topic/297502-r33-parts/
UPDATE I NEED THIS STUFF GONE MAKE AN OFFER I NEED THE SPACE WANT IT GONE SOON OR IT CAN ALL GO TO THE DUMP
underside of the bootlid plastic $30
2 stock cats one with the centre bashed out $15 each
aac valve $30
stock top part of the rb25det plenum $50
stock boost soleniod $30
stock rear bar damaged just needs a plastic weld my exhaust burnt it :nyaanyaa: $40
stock front pipe heat shield $10
stock dump pipe heat shield $5
perfer pick up but will post at buyers expense
Edited by Turbo 33
https://www.sau.com.au/forums/topic/297502-r33-parts/#findComment-4962835
  • 3 weeks later...
i also have 4 rims no tyres 3 rims are good 1 has a buckle not sure on model or offset but i can find out the offset tomorrow there 18 by 8 they have abit of gutter rash will also get some more pics tomorrow looking for around $350 for the 4 of them or swap for items of interest eg. trust front bar, stock 33 turbo, etc let me know what you have
aac valve $30
stock rear bar damaged just needs a plastic weld my exhaust burnt it $40
stock cat with centre bashed out $20
Edited by Turbo 33
https://www.sau.com.au/forums/topic/297502-r33-parts/#findComment-5019685
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
