Hey guys,
I'm after 2 new or second hand tyres: 255/35R18 for the front of my Supra. The car is undriveable ATM so I'm after these ASAP!
I'd like them to be the same (obviously), and from a well respected brand, such as Bridgestone, Dunlop, Michelin, etc. Nothing like Nexen, etc.
Price: basically as cheap as possible so 2nd hand is probably the way to go, but if 2nd hand I'd like at least say 75% tread left - but they'd have to be *really* cheap if they're that worn. I will pay any reasonable price - if it is in fact reasonable.
Don't mind if they're DOT approved or not, but if they aren't, it would be nice if they're a very good tyre at a good price.
Please reply here or PM me if you can help me out, and make sure you leave a price. I don't want to have to chase people up or ring around - simply don't have the time for that...
Thanks!
Note: I've already searched everywhere on this forum and can't find anything in this size. Unfortunately, this is a particularly hard size to find! :thumbsup:
https://www.sau.com.au/forums/topic/297531-wtb-2-x-25535r18-tyres-asap/
  • 3 weeks later...
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
