Im bolting the Brembo's from my Autech 260RS (R33 GTR one's) replica onto my R34 Gt-t then the Gt-t brake's back onto the stagea.
Anyone know if they will be a direct swap? I was thinking on the Gt-t the backing plate may need some trimming for the larger rotor?
Brake line's etc same thread?
Rear handbrake shoe's etc be OK?
Any problems im going to hit?
Cheer's.
https://www.sau.com.au/forums/topic/297669-r33-gtr-brembos-onto-a-r34-gt-t/
Cheer's.
I always remove the backing plates, so I don't worry about them being in the way. Plus I use braided lines so I don't know if the standard ones fit. Rear handbrake has never been a problem as the rear rotor internal diameter is the same.
The calliper to hub bolt sizes (diam and thread) are different. I can't recall, maybe M12 to M14, the smaller size bolts are on the Stagea and R34GTT and the larger size bolts on the GTR's. From memory Duncan used spacers to fill the larger hole sizes for fitting the GTR callipers on to the Stagea using the smaller diameter Stagea bolts.
Cheers
Gary
Cheers
Gary
Being that the stagea allready has 33 GTR brembo's possibly the hub is 33 GTR to, being autech one's? Well hopefully.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
