like i say to everyone who comments my thread and wants to act like they know everything about the car. theres a number there for a reason CALL IT IF YOU ARE INTRESTED. and i never said a rebuild will cost two grand dunno were you pulled that from and compliance should cost about 2 grand and for the f**king 100th time call the number if your intrested coz anyone who would be would have done it and not commented the thread. cheers. and no i dont have nothing to hide with the car. im more then happy to show all paper work and receits to a SERIOUS buyer. and transcar in campbellfield imported this car down for me!
Edited by loky
  • Replies 76
I understand what your saying Loky, but I think your replies are hurting any chance you have of selling this.
As a neutral outsider, I would'nt consider buying this because of the way you answer.
If you were more upfront and answered people questions in a thread you started rather than discussing it privately by pm indicates all is not well.
This may be a stupid question but if you actually complied this car yourself, wouldnt it sell infinitely quicker?
It may be your only choice, good luck anyway champ, just trying to help.
mate what your saying is right. but whats so hard about making a phone call if you have genuine intrest? there are no grey areas about this car. i am showing all paper work from the test report i got for the car when it was in japan to even giving my mechanics number to even speak to him about the car. and yes if i did get the complied it should sell quicker but at the same time im too jammed up financially to do that at this moment. but thanks for your asking atleast your not a smart ass like the other idiots. cheers buddy
Loky my advice is the fix it up properly and wait till end of the year or next year to sell if you really have to.
You never know, you might end up keeping once everything works.
thanks for the adivice mate. if it dosent sell in the next month and a halfor around there anyway i will be fixing it and keeping it. but till then i might as well leave it on the market.
for ten grand you can have the body of the car with no running gear. dont make me stupid offers
Sorry to butt in but those offers are not so stupid- 10 K is about right for that car as it is nothing special with mechanical problems, if it was so easy then do it your self and get the $20 k that you think it's worth , you can buy a mint Vspec series 2 these days for $23K! If you want to sell then be realistic and stop wasting peoples time.
you f**king ball brain! if i had the money to do it myself i would of dickhead! if you havent got anything good to say keep your comments to your self. ten grand is the price if you dont like it stay out of the thread!
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
