there's a few floating around in the for sale section at the moment:)
a red set and a blue set for around 500-600 just do a quick search and i'm sure you'll find.
Cheers.
https://www.sau.com.au/forums/topic/298254-rb26-cam-covers/#findComment-4962189
Just got a set in mate, vgc - the cover for the cam gears has a greddy sticker on it, but otherwise they're pretty clean can email some pics :)
$380 the set, located in Bayswater vic :)
https://www.sau.com.au/forums/topic/298254-rb26-cam-covers/#findComment-4963841
