extra $40 =
Forza Motorsport 2GB USB Storage and keychain: Show off your Forza pride with these specially branded items.
Forza Motorsport VIP Membership* and Exclusive Car Pack*: Want to be a top painter, tuner, driver or just more active in the community? VIP membership is the way to get yourself noticed. Includes special treatment within the online Auction House, Community Storefront and on the Forzamotorsport.net forums. Also includes 5 of the hottest cars from the roster of Forza Motorsport 3, available only through your VIP membership.
  • 2009 Aston Martin DBS
  • 2009 Chevrolet Corvette ZR1
  • 2007 Ferrari 430 Scuderia
  • 2007 Lamborghini Gallardo Superleggera
  • 2007 Porsche 911 GT3 RS (997)
Exclusive Collector's Edition Car Pack*: This one is for the fans. This pack includes 5 cars that have been hand tuned and hand painted by the developers at Turn 10 to fly the Forza Motorsport colors.
Exclusive Forza Motorsport 3 Theme:* Customize your Dashboard experience with this limited availability Xbox 360 theme.
If you crave cars, you won't want to miss another perk of the "Forza Motorsport 3" LCE – an Exclusive Collector's Car Pack, personally hand-picked, tuned and painted by the team at Turn 10:
  • Audi R8 5.2 FSI Quattro (Forza Motorsport 3 Cover Car)
  • Acura NSX (Forza Motorsport Cover Car)
  • Nissan Fairlady (Forza Motorsport 2 Cover Car)
  • Aston Martin DB9 (Forza Motorsport 2 European Cover Car)
  • 2008 Dodge Charger Stock Car (with Xbox 360 livery)
https://www.sau.com.au/forums/topic/298545-forza-3/#findComment-4967298
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
