Hey guys
I need to buy some new coilpacks soon but as people know there is a difference between the coilpacks for a Series 1 R33 and a Series 2. Now looking at my engine in the photo attached and other people's Series 1 engines, shouldn't there be a largish ignitor type pack where the red circle is. Where as it looks like I have this plug which I have seen on Series 2 engines.
So as you can see I'm a little confused (that or im just a noob and missing something). The car is a Series 1 1994 model.
Any help will be appreciated
Cheers
https://www.sau.com.au/forums/topic/298730-help-for-decision-on-coilpacks/
you'll require series 2 coilpacks than, why are you replacing them tho? are they missing? if there is nothign wrong with them, dont waste your money on replacing them as the stock ones are by far the best out there when they are in good condition, the only ones that come close to a decent set of stockers are splitfires.
Ye they are missing pretty bad are high rpm and load. Put my mates good ones in there and no problem. Yep am going to buy the splitfires.
Im just curious why would someone replace the ignition system on the car to using series 2 coilpacks? Any advantages with having the ignitors inbuilt?
you sure your cars 94 not 95 or so? i cant remember what year the series 1.5's started which had the s2 coil setup
Ye the series 1.5 started in late 95 I think but mine is registered as 94, plus I don't have ABS which I know Series 2 had. Other than that I don't know how else to distinguish a series 2 engine....
Now Im wondering if you change the coilpacks to series 2, would they have to change the rest of the ignition components or can you easily convert from series 1 coilpacks to series 2 ones?
abs was an option, i had a S2 front cut that didnt have abs a while back, get your vin fasted could tell you a bit more. but i wouldnt worry about it... providing its all working
I should mention before I sound stupid that my mates one I tried is from his Series 1 R33 which has the same plug at the back of the engine as mine, that's why I wasn't sure if both of us have series 2 coilpacks so ye
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
