as above i have a brand new trust clear timing belt cover to suit rb26 engines.
has only ever sat on the motor as it was on the motor i bought and i didnt want to use it.
im after $130
will post at buyers expence, or pick up can be arranged from wollongong
https://www.sau.com.au/forums/topic/299008-trust-clear-timing-cover/
